If anybody can highlight which Layer 2 messages should appear in 5G logfiles in EN-DC and why?
As we know EN-DC all control is going through MCG, rest PDCP harq and other messages should be seen in Layer 2 when analysing a 5G logfile?
There is no PDCP Harq. Harq is implemented at MAC layer.
I think beam changes should be seen in Layer 2.
Also al MAC control elements.
I believe in 5G PDCP can do retransmissions, during HO.
You mean when 5G base station is connected to 5G core network?
I can not recall if it is the same with NSA.
BUT FOR 5G SA, yes.
But restransmission is done by RLC layer, and AM do this job.
Yes RLC does retrasmissions.
Harq retransmissions are also possible at MAC layer, there is no harq at PDCP layer.
For the initial question, PDCP, RLC and MAC.
Layer 3 RRC reconfiguration in Master LTE node gives the details of PDCP entity in 5G NR as shown below:
Here the PDCP bearer is split at MCG(LTE node) and then more than one RLC layer ie LTE RLC and 5G RLC is used for data transmission,
[5G-NR RRC_F40 Data] :
value RadioBearerConfig ::=
drb-ToReleaseList
4
drb-ToAddModList
cnAssociation eps-BearerIdentity : 5,
drb-Identity 6,
pdcp-Config
drb
discardTimer infinity,
pdcp-SN-SizeUL len18bits,
pdcp-SN-SizeDL len18bits,
headerCompression notUsed : NULL
moreThanOneRLC
primaryPath
cellGroup 0 ## means uses more than 1 RLC with MCG SPLIT
ul-DataSplitThreshold infinity,
pdcp-Duplication FALSE
t-Reordering ms200
securityConfig
securityAlgorithmConfig
cipheringAlgorithm nea2
keyToUse secondary ## uses 5G NR also in lower layer
please, why has SCG split been more preferred by industry vs. MCG split?
