Hi Guys…after I enable EFACH in Huawei the RAB Setup Fail CS/PS UpdtNum increases. Is it normal?
It also increases the RNL failures.
RAB.FailEstabPS.Other High in some cells | 1 | 456 | March 7, 2021 | |
eRAB Drop Rate increased after Software Upgradet | 1 | 620 | August 16, 2021 | |
DRB.Add higher than SgNB.Add in NsaDc | 1 | 819 | March 15, 2021 | |
Counter to check drop high due to abnormal UE | 2 | 1079 | January 24, 2022 | |
How to restrict abnormal UEs during eRAB phase other than Abnormal UE Scheduling switch in LTE? | 0 | 374 | September 14, 2021 | |
Any help with call drop ratio cause as abnormal release radio at Huawei? | 0 | 977 | September 24, 2017 | |
Huawei 3G Drop increase after MOCN | 0 | 465 | October 13, 2021 | |
High 5G DRB Abnormal Relase Rate | 1 | 513 | March 13, 2021 | |
UE prach failures | 0 | 436 | January 5, 2021 | |
Why eRAB normal release plus abnormal release sum is less than number of eRAB successful established? | 1 | 518 | October 25, 2022 |
