Hi guys just want to know how can you implement AMOS command restriction on a per team level.
Sample:
NOC Engineers- Can execute only lst bl deb but cannot execute set command
Configuration Ran Engineer- Can execute anything
Field Engineers-Can execute only all query commands
Hi, @Dennis_Ong, you need to create custom roles and select capabilities. For AMOS it is:
AMOS | amos_em_m2m | read | Allows execution of the MO READ (get) commands via m2m communication. |
AMOS | amos_em_m2m | create | Allows execution of the MO WRITE (set) commands via m2m communication. |
AMOS | amos_em_m2m | patch | Allows execution of the MO WRITE (fset) commands via m2m communication. |
AMOS | amos_em_m2m | execute | Allows execution of the TELNET (fro) commands via m2m communication. |
Than assing that roles to users. Also you can create Target Groups for specific network elements and assign it to users. There is no possibility to restrict commands.
Thank You @vlr9999! I’ve also looked into that but my problem we want to limit commands on a more granular level. Sample I want all read only commands plus Block/Deblock cells, reset nodes but shouldn’t be able to Set parameters. Is there such a way?
@Dennis_Ong , we’ve been asking E/// support about this - there is no other way.
