Hi all,
Do you have or know any non-Ericsson tool/macro to be able to create xml (bulk) files for changing parameters in the Ericsson ENM 4G nodes?
Thanks in advance for all your suggetions.
GM
Hi all,
GM
You can create a script if you have CIQ available, and run the script in ENM.
Hello tbodog,
Is CIQ a Ericsson tool? or is it a third party tool?
CIQ is a 3rd party tool from the operator.
Is thera a posibility to get a copy of it?
Sure I can share with you a sample copy of CIQ.
Hi Tbodog,
can you please share with me too.
Is there any open tool (public domain) that can do this?
As the original request “tool/macro to be able to create xml (bulk) files for changing parameters in the Ericsson ENM 4G nodes”?
I am not able to use tools that requires license/paid… As per my understanding, this CIQ is for third part vendor, and is NOT free, am I right?
So far I have not been able to find any. And now the 2G as well is implemented in ENM. It would be great to have one which can do all.
Do you have any specific tool to generate scripts XML , i have the CIQ’s.
Hello,
who is the vendor? Nokia or Ericsson. I think that I can find an XLM Generator for Nokia.
The Vendor is Ericsson.
Please send me if you have any XML generator for that.
Could you please share it?
In ENM Parameter Management
can generate XML.
nothing found Parameter Management in ENM
Select parameter, object in topology, then Save
Press Generate Bulk
button
Hello,
Thanks for the update man.
I need another informatiomn for AT&T, what is portal name for Router scripting and Router Integration
