If an NR UE does not support the configured NR cell bandwidth, which parameter needs to be adjusted to ensure the user can still access the cell?
Vendors: Huawei & Ericsson.
Huawei and Nokia have a feature that allows configuring multiple BWPs, whereas Ericsson has the feature but does not support different bandwidths.
Here’s an example:
I’m not sure if I fully understood your question, but in Huawei, when users are REDCAP, we need to configure NRDUCELLBWP as follows:
Command:
MOD NRDUCELLBWP:BWPCONFIGSWITCH=UE_BW_ADAPTIVE_SW-1,ULMINCARRIERBW=20M,DLMINCARRIERBW=20M;
This configuration ensures that REDCAP UEs can access the network.
This might be similar to what you need to configure in your case.
Yes, we have a cell with 80 MHz bandwidth, but the UE does not support the full 80 MHz.
There are multiple re-establishments due to reconfiguration failures, leading to ENDC failures.
What measures can be taken to prevent this issue?
Do you have the device model mapping available?
