Hi all,
I hope you can help me with this one, I am looking for Ericsson 5G NR CellRange that can be found in Ericsson NR RAN library. Radio Systems NR RAN 20.Q3.5 Random Access: NR NSA
CPI Radio System Radio System Software NR Radio Access Network
There must be a table for Ericsson NR low band, e.g. NR700 or NR1800, mapping Preamble Format, Cell Range Value and Number of Required RACH Root Sequences in Each Cell. Use Preamble Format=0 + Number of Required RACH Root Sequences in Each Cell=3 as described in another table about “PRACH Configuration Indexes” mapping to “Preamble Format”.
Many thanks,
Regards,
Ricardo
Related Topics
How to calculate Number of required RACH Root Sequences in each cell? | 5 | 714 | December 20, 2023 | |
NR PRACH queries related to configurations and parameters from spec 38.211 | 0 | 511 | August 9, 2021 | |
How Cell Size is determined from length of preamble format? | 37 | 11681 | December 2, 2022 | |
Where can I find a NR 5G initial Access recording? | 2 | 492 | December 18, 2022 | |
5G RACH attempts failure issue in 5G n78 band Standalone | 10 | 3858 | February 25, 2023 | |
5G RACH doubts | 7 | 15158 | February 24, 2021 | |
What PRACH format most 5G operator using? | 4 | 282 | March 14, 2024 | |
What's the formula or KPI to have 5G NSA PRB DL and UL utilization by cell? | 5 | 895 | December 23, 2023 | |
5G NR ScellIndex configuration | 6 | 3126 | May 24, 2020 | |
Deciding factor for sCellIndex definition | 0 | 640 | July 1, 2020 |
