Ericsson enodeB anr logs
Hello, how is it possible to see ANR logs on ericsson enodeb?
Hi, @Hakan_Murat_Karaca you can try this logs, but it maybe obsolete and depends on SW level. Best way is to ask E/// support.
te e all Ft_RRC_ASN
te e all Ft_S1AP_ASN
te e all FT_X2AP_ASN
te e all Ft_ANR_COMMON
te e all Ft_CELL_ANR_MEAS
te e all Ft_UE_ANR_MEAS
Hello @Hakan_Murat_Karaca !
which ANR logs did you want to see? may be you want to view ANR counters?
please, describe it in more detail. Thanks.
Thank you @vlr9999
Hello @Nekto,
I need to learn why ANR did not create some neighborrelation even though it seems it detected that neighbor to create. I need logs to check this.
Thank you.
Hello @Hakan_Murat_Karaca ,
If the ANR function is enabled on the Node, then you need to deal with the problem in detail only using the traces that @vlr9999 wrote about earlier. But the traces still need to be decrypted. Therefore, it is better to contact the vendor’s technical support.
Thank you @Nekto.
