Hi Dear Expert.
Can someone share the Ericsson export command inventory (CLI) for 5G (NR)?
shm export --hardware --nodes NODENAME
Thanks!
For export all NR, can I use *NR * on NODENAME?
--savedsearch or --collection
Yes.
“Enter node name. Wildcards must be used before and/or after partial names. e.g. * RBS * to filter on all node names that contain ‘RBS’.”
I tried, but this one but doesn’t work.
shm export --node *NR * --hardware --jodname
My bad, it is only for cpp-nodes, for radionodes cmedit export
Try this: Boda - Ericsson CM Data (Dump)
And this: Boda - Ericsson Inventory Data (Dump)
This command here should work very well:
cmedit get 5G-SPJP01 FieldReplaceableUnit.(productData.(productName,productNumber)) -t
If you want to save the entire network to a file, do this:
cmedit get * FieldReplaceableUnit.(productData.(productName,productNumber)) -t
Beforehand, a tip - Press CTRL+Enter → it will prompt you for a file name to save in C:\Downloads.
