The QCI subscription quanta values (QciProfilePredefined.qciSubscriptionQuanta and QciProfileOperatorDefined.qciSubscriptionQuanta) of all E-RABs (both GBR and non-GBR services) Configured in the cell are added.
qciSubscriptionQuanta initially can be set equal to (or proportional to) the typical bitrate of the beare.
cellSubscriptionCapacity: can be calculated based on the available PRB resource in the cell, which depends on the bandwidth. The calculation is usually performed based on the downlink resource alone, disregarding the uplink re-sources.
The available downlink PRB resource is then multiplied with the typical spectrum efficiency in the cell.
