Can 3G payload go on the same IP-addresses as SCTP between nodeB and RNC?
We have an Ericsson RNC3820, and we see UDP packets on one of the IP-addresses defined as SCTP.
How can you print which IP address is used for payload vs sctp?
Hi, @Bartonsen, there are two ip addresses per HostEt in IUB interface for RBS signalling, user data and synchronization. The one reservedBy IpAccessSctp
is for signalling (NBAP) and (Iām not sure) for user dara. The second is for synchronization.
Hi @Bartonsen . Yes UP and CP traffic may use the same RNC IP-addresses. You may check current configuration with sti
amos-command.
