VLAN & QinQ are 2 important protocols used in networking: wireless and Transmission.
VLAN can be used to differentiate services and Traffic clients transmitted on the same network.
VLAN defined as IEEE 802.1Q.
VLAN header is 4 bytes.
Most imports info in the header is the 12 bit VLAN ID.
IEEE 802.1Q allow use to use up to 4094 VLAN.
With the expansion and developments in the network domain we need for more VLANs
That’s why we have to use QinQ.
QinQ allow use 2 VLAN Tags (inner and outer).
First tag called C Vlan and 2nd Tag called S VLAN.
C VLAN is the customer VLAN and used to identify the user.
S VLAN is the service provider VLAN and it identifies the carrier or provider.
We can use QinQ in different application scenarios like differentiation between voip services, internet access and IPtV as an example.
That can be done easily assigning different users a different C VLANs, and assign different S VLANs to different services.
QinQ defined as IEEE 802.1ad.
QinQ extend vlan range and allow up to 4094 * 4094 vlans.
QinQ can connect L2 networks in the same vlan through backbone network.
Customer router add and remove vlan tag , service provider add and remove s Vlan tag during the traffic flow.
We can also call it VLAN stacking.
It’s a way of VPN implementation and used by service providers.
Later will explain what’s VXLAN and the difference between VLAN , QinQ , VXLAN
LinkedIn:
