Exporting PM files from Huawei OSS: Path and Activation
Hello Huawei Experts,
How can PM files be exported from Huawei OSS?
I initially tried the following path:
/opt/oss/server/var/fileint/pm/
However, this folder doesn’t appear to exist in Huawei OSS.
Could you advise if there’s an alternative path or if specific measurement activation is needed?
Huawei NIC
If you have access to U2020, you can export the files through NIC (Network Information Collection).
It’s much easier.
Thanks! Any step by step?
I recommend to use Filezilla to do so.
On the other hand I think the path you have is wrong.
This is the correct path:
Yes, this is the best and easiest way!
Huawei NIC
These are the steps:
  1. Navigate to Network Information Collection:
    • From Maintenance window [to the top right].
  2. In the Task Creation Section select [Customized Collection]
  3. Choose the Product Type from the Drop down menu.
  4. Choose the NE Version for which you want to export the PM Files [You can choose different versions together].
  5. Name the task.
  6. Click Next
  7. Choose the NEs wanted from the available NEs window and press the [>] button.
  8. Click Next.
  9. Choose the wanted PM counter from the Available Collection Window.
    • Usually [pfm, perfromance, pm] for Perfromance logs.
    • Customer can try the above key words from the seach bar.
  10. Press [>] after finding the desired collections.
  11. Click Next.
  12. Choose the time window of the collection wanted.
  13. If the customer wants a perioidic collections - do so.
  14. Finish.
  15. From the Task Management select the Task.
  16. In the download results in the bottom side of the window press Download.
