Hi all,
someone to use feature RAN 2717(Smart Lte Layering) in Nokia and to know how UE select the eutran after rrc_connection_release, If there are more than one defined ADJL’s with different Abs_priority?
This is blind redirection from wcdma to lte but UE always select the lower priority earfcn
Thanks in advance…
Related Topics
UE to choose the best beam without considering other beams | 4 | 1266 | March 12, 2020 | |
4G router data deactivated, but it keep backing to 4G (don't stay in 3G) | 0 | 229 | November 18, 2022 | |
Block the UE to latch on 4G from RAN node end | 3 | 456 | May 15, 2021 | |
E-UTRAN New Radio - Dual Connectivity (EN-DC) across different vendors | 0 | 235 | March 5, 2024 | |
How to check reselection attempt in LTE? | 2 | 661 | October 28, 2022 | |
CSFB to 3G with Release with Redirect | 0 | 386 | May 24, 2023 | |
RAT Selection in Roaming: 3G vs. 2G/4G | 0 | 46 | July 30, 2024 | |
How to measure reselection from 3G to LTE? | 3 | 2325 | December 2, 2022 | |
Parameter for 4G as qsearchC for reselection from 2G to 4G in packet connected mode | 1 | 259 | December 20, 2023 | |
Reduce CS Fallback (4G-2G) time in Nokia system | 5 | 2426 | January 30, 2020 |
