Field test recommendations
I need few practical inputs for below points to prepare for field testing.
Need to assume guy only having mobile handset which can show generic info like RSRP, SINR, CQI, etc.
  1. Throughput test: to select best points to test Throughput need to check SINR > 28 dBm DL BLER < 10% at point (best TM mode) so optimize MCS can be allocated to UE with best modulation.
  2. CA point: to start for CA activation person can download heavy file so Scell activation can be done on volume basis.
  3. To check network configured antenna ports person can check MIB message contents and corresponding RI can be checked in tool to get best point.
Please add any important point missed so I can guide field team.
Hi ,
Adding couple of points…It might help…
》MIMO
》 Transmission power between the UE and the base station, both uplink and downlink
