UE doesn’t indicate anything, eNB decides based on UEs RLC buffer.
Succes rate may be poor because most of SgNB addition might be happening due to LTE cell edge UEs.
Near or far with respect to what?
Thanks!
For beam like we have different beam index for 6 SSB config 5_1, so how beam distinguished for far and near region?
There is beam ID associated with every beam broadcasted in SSB.
UE just measure beams having RSRP better than certain threshold.
In some vendors, the decision of which beam to be used is either decided by the NW side through the RRC Mode configuration message, or it can be chosen by UE, which could be more optimal.
Thanks is there any parameter for it?
How to decide it?
Yes for Huawei ‘ssbmodeswitching’.
- Either set it as ‘RRCMODE’ this parameter will let gNB decide.
- Or set ‘NOSWITCH’ this will let UE decide optimal beam.
For FR1 < 3 GHz → 4 SSB
For 3 to 6 GHz → 8 SSB
For FR2 > 6 GHz 32 SSB (analog BF)
I think it’s as per standard…
Oh, yes, 32 vendor limit.
As per 3gpp 64.
