For DSS between LTE and NR for rate matching does ZP CSI-RS used? Or NZP?
Related Topics
Configuring CSI for NR spcell and NR scell in NSA | 0 | 321 | April 1, 2021 | |
In NSA, UE use same RNTI for 4G and 5G? | 1 | 363 | May 18, 2021 | |
UE not sending ratematchinglte-crs IE | 3 | 657 | April 26, 2021 | |
How IE to check if the device support DSS? | 1 | 702 | February 24, 2021 | |
Does UE not sending ratematchinglte-crs IE means DSS not supported by UE? | 1 | 453 | April 1, 2021 | |
If a UE doesn't support DSS in NSA mode won't it support in SA mode also? | 2 | 361 | April 21, 2021 | |
Any network in NR using 15 kHz sub carrier spacing globally? | 4 | 424 | June 7, 2021 | |
UEs supporting DSS | 4 | 915 | January 8, 2021 | |
DSS Restriction on LTE-NSA Anchor | 4 | 1922 | February 12, 2020 | |
LTE interference on NR | 1 | 335 | February 9, 2024 |
