For ENDC mode, what parameters need to be enabled on 4G side and 5G side?
Hello Expert,
Does anyone know for ENDC mode, what parameter need to be enabled on 4G side and 5G side?
Vendor Ericsson.
You can set endcprofile=1.
Need to check endcprofileref.
endcallowed plmnlist need to be defined.
upperlayerIndR15Usage need to set.
Neighbour for 4g-5g & 5g-4g need to set.
Check 5g cabinet other settings.
Are you asking this question from planning point of view?
If yes, than I share some insight from planning tool point of view.
In 5G, NSA, ENDC, from 4G which parameters required to add 5G NRcell?
Vendor Huawei
Can you please share the parameters and their MOs in detail that are required to be set on 4G and 5G sides for ENDC mode.
On Ericsson, are there any parameters I need to switch for voice in ENDC?
Voice is always handler over LTE in NSA.
But there is the option to disable NSA for VoLTE calls.
Do I need to set a parameter for this?
My issue is when volte is on UEs aren’t camping on 5G but when volte is disabled in setting they are camping on 5G.
I need them to camp on 5G even with VoLTE ON.
When you say camp you want to see the 5G icon in idle?
Or do you want to have NSA during VoLTE calls?
What do you see in message flow, does UE gets an attach reject?
No.
UE in idle mode and connected mode if VoLTE is on in setting is acting like NSA doesn’t exist.
But when VoLTE is OFF it is connecting to NSA and throughout is NR.
Maybe it helps, in case your 5G NSA is on FR2…
Prerequisites for SN Addition:
FRinhibitEndcFr2Volte = false, Whether EN-DC FR2 is inhibited during VoLTE.
