For Microwave mainly we use 3 main bands
Traditional band 7-42 GHz
E band 71-86 GHz
V band ( used in some specific applications like military and small distance transmission )
For optical Transmission we have 3 main optical windows
- 850 nm, 1310 nm, 1550 nm
We have 2 types of high capacity transmission technologies
- CWDM
- DWDM
CWDM used in medium distance and capacity transmission
DWDM used in ultra Long distance and ultra high capacity transmission
DWDM can reach more than 5000 - 10000 km and tens of Tera bits per seconds
We usually use multiple frequency ranges in optical as described below in table
Most common band used is C band
In case of capacity expansion needed we can use L band
C band and L band has the lowest attenuation coefficient and highest performance
Each band has its attenuation and dispersion coefficient based on optical fiber type used
We have 2 main fiber standards used
- G652
- G655
LinkedIn:
