GSM to LTE Reselection
Hi All,
Is there any command for GSM to LTE Reselection, like command UCELLNFREQPRIO for 3G to LTE Reselection?
Apart from GEXTLTECELL and GLTENCELL.
Vendor is Huawei.
FASTRETURNMEASSPT, MO GCELLPRIEUTRANSYS
For the fast return.
Fast reselection to neighboring LTE cells.
Check GCELLPRIEUTRANSYS MO for G2L reselection parameters.
Also in GCELLHOBASIC MO there is one parameter “LTE Cell Reselection Allowed”.
Thanks @Ali.raza, I have defined like this.
I taught something like UCELLNFREQPRIO would be there too, like in 3G.
So for GSM, is this enough for reselection, CSFB normal reselection?
Check also this MO: GCELLSOFT.
I guess there is one or 2 parameters related to the CSFB procedure.
Here is the Huawei script:
  1. ADD GEXTLTECELL: EXTLTECELLID=xxxx, EXTLTECELLNAME=“4GXXX”, MCC=xxx”, MNC=“xx”, ENODEBTYPE=MACRO, CI=xxx, TAC=xxxx, FREQ=3200, PCID=xxxx, EUTRANTYPE=FDD;
  2. SET GCELLHOBASIC: IDTYPE=BYNAME, CELLNAME=“XXXXX”, HOCTRLSWITCH=HOALGORITHM1, LTECELLRESELEN=YES;
  3. SET GCELLPRIEUTRANSYS:IDTYPE=BYID,CELLID=XXX,GERANPRI=1,UTRANPRI=3,EUTRANPRI=7,THREUTRANHIGH=3,EUTRANQRXLEVMIN=8,THRUTRANHIGH=6,UTRANQRXLEVMIN=5;
  4. ADD GLTENCELL: IDTYPE=BYNAME, SRCLTENCELLNAME=“XXXXX”, NBRLTENCELLNAME=“XXXXXX”, SPTRESEL=SUPPORT;
  5. SET OTHSOFTPARA: Send2QuterFlag=YES;
