Hi all,
Anyone have any guide for inserting or creating template in NetAct to fetch KPI?
Do you want to create a report?
Yes.
I have created few basic reports, but would like to know how to insert if any Excel format template already given.
You can upload in reporting suite.
Ok, thanks.
Any particular steps need to be followed to import that excel sheets to get kpi report?
How many counters are you planning to add?
Some may be KPIs, which will involve multilple counter sets and you will have to make custom KPIs beforehand else even if you upload the excel it will not be able to generate.
If its only counters then it shouldn’t be a problem.
