Hi all.
Could you please guide me on where I can check the details of UEs that support the N71 (600 MHz) 5G band?
Hi all.
To determine if your phone supports the N71 (600 MHz) 5G band, you can visit cacombos.com. By entering your phone model in the search bar, you’ll access detailed information about its supported 4G and 5G bands, including all possible uplink and downlink combinations for both NR (New Radio) and LTE. This resource is particularly useful for verifying band compatibility and understanding your device’s network capabilities.
This is specific to a particular model. I need to know, in general, how much device support is available for this band compared to other bands.
I don’t believe you’ll find specific statistics that provide the percentage of 5G phones supporting NR Band N71.
I found the GSA website where you can download device data:
Yes, it is a good option.
But accessing detailed device data from the Global mobile Suppliers Association (GSA) typically requires a paid membership. However, the GSA does offer some free resources and reports that might provide the information you need. For comprehensive data, a membership would be necessary.
They also offer a free membership option, which provides access to some important data.
