High traffic difference between two LTE carriers in band 8
Hi experts,
Working with Nokia RAN and we are seeing a very high difference in traffic trend between two B8 carriers. Both 10MHz FDD, same footprint, same power levels, identical mobility strategy, SIB configuration. Still, c1 of B8 holds less than half of the total traffic registered in c2, this is seen in number of setup attempts and also PDCP SDU volume. RF scanner indicated no offset in signal levels.
Playing with the order of mobility profiles (both idle and conn) helps shift some of the traffic, but still offset between carriers is quite high.
Any ideas what could be causing this would be much appreciated.
