How can I check if CA is enabled or not for Huawei
How , I can check CA enable or not ? Vendor:huawei
yes, depends on your strategy.
CA-Group-based Configuration/Frequency-based Configuration/Adaptive Configuration
Thanks bro for the reply
Here we are using frequency based
How I can check its enabled or not
check these switchs
Any mml command
NODEBALGOSWITCH:CAALGOSWITCH=PdcchOverlapSrchSpcSwitch-1&CaCapbFiltSwitch-0&PccAnchorSwitch-1&SccBlindCfgSwitch-0&FreqCfgSwitch-1&SccA2RmvSwitch-0&CaTrafficTriggerSwitch-0&H
and u need to check also the blind scc is it taken as strategy or not…
Thanks a bunch
If eran12 check also cellalgoswitch
Run dsp pccscelllist and run dsp celluecnt
