Hi Everyone, I have a question:
How can I check if one antenna has 64 rx-tx or 32 rx-tx NR NSA midband?
I mean from the OTA message (I’m using QxDM) and I can not see any message like CSI Feedback.
Does anyone have any idea?
Tony
1
Related Topics
Check if Operators is having SA deployment or NSA deployment | 2 | 316 | May 21, 2022 | |
How to check current serving beam ID in QXDM logs of NR SA? | 0 | 364 | September 27, 2023 | |
How to tell from traces if the user is being served by 5G NSA or 4G in Core? | 3 | 242 | April 17, 2024 | |
How to check capacity gain achieved between 2x2 MIMO vs 4x4 MIMO vs 64x64 through OSS KPIs? | 2 | 741 | July 12, 2021 | |
Parameter to check MIMO | 0 | 644 | March 4, 2021 | |
How to check LTE Advance or LTE License in logs? | 0 | 188 | December 29, 2023 | |
5G NSA RE Power check using drive test | 2 | 556 | April 6, 2023 | |
How to check the channels number related to a PRI pilot numbet in AGCF? | 1 | 53 | July 27, 2024 | |
How to check NR cell selection priority in ENM? | 0 | 333 | October 21, 2022 | |
Where to check SGSN IP configuration details in Nokia / ZTE / HUAWEI RNCs? | 1 | 154 | March 15, 2024 |
