How can I extract LNCEL counters for report creation?
Dear All:
How to extract LNCEL counters for report creation?
For example; I tried to search ulpcRefPwrlAw and A2timetotriggerRedirectRsrq
Nokia fddlte16
I tried to search for these in Report creator but couldn’t find the counters
ulpcRefPwrlAw and A2timetotriggerRedirectRsrq are parameters
you are searching for counters!
:+1:t4::+1:t4::+1:t4::+1:t4:
Thanks
so if you are searching for counters related to interference aware power control you can find them in feature description documents
Sorry
Actually I got confused.
Do I need to take some special steps to activate these parameters? ?
Thanks
