Hi Folks.
For Ericsson, how can we get pscellchange attempts and success, source and target cell?
Is there any AMOS command to get at least for one site / cell?
Hi Folks.
pmx . pmEndcPSCellChangeAttInterSgnb -m 1
pmx . pmEndcPSCellChangeSuccInterSgnb -m 1
(Just replace intra with inter for Intra HO)
Use ebs counters, it will give you per relation countd
Thanks all.
Please is there a way to have it per neighbor relation?
As this command will give stats per cell, I need to know with wich neighbor the pacellchange is failing…
Hi Ali,
You need to use pmebsendcpscellchangeattintra/intersgnb and pmebsendcpscellchangesuccintra/intersgb to check PS cell change failures on relation level.
