How Carrier Aggregation (CA) impacts VoLTE (Voice) Services in 4G/LTE Networks
Carrier Aggregation (CA) enables a UE (User Equipment) to use multiple component carriers (CCs) simultaneously to increase the overall data rate and capacity of the network. While CA can benefit data services, it can potentially degrade the VoLTE (Voice over LTE) performance in certain scenarios.
Here are a few ways in which CA can potentially impact VoLTE performance:
  1. Increased Interference: When a UE uses multiple CCs for data services, it can potentially increase the interference in the frequency band used for voice services. This can result in degraded voice quality and increased dropped calls.
  2. Resource Allocation: When a UE uses multiple CCs, the network may need to allocate resources from both CCs for VoLTE services. This can potentially result in suboptimal resource allocation, leading to reduced voice quality and increased dropped calls.
  3. UE Capability: Not all UEs can support VoLTE and CA simultaneously. In such cases, the UE may not be able to properly handle the additional signaling and data traffic associated with CA, leading to degraded VoLTE performance.
  4. Network Congestion: When the network is congested, the additional signaling and data traffic associated with CA can potentially degrade the VoLTE performance by causing delays and dropped calls.
It’s worth noting that the impact of CA on VoLTE performance can vary depending on the specific network configuration, UE capabilities, and traffic conditions. In some cases, CA may not have a significant impact on VoLTE performance, while in other cases, it may lead to degraded performance.
To mitigate the impact of CA on VoLTE performance, network operators can implement various techniques such as:
  1. Interference coordination
  2. Dynamic resource allocation
  3. Prioritization of VoLTE traffic over data traffic
Also, vendors do provide special features to achieve this.
Does a UE use carrier aggregation for VoLTE since data requirement is small?
Carrier Aggregation is not needed for VoLTE. What if the UE downloads the data and configures multiple sCells due to Carrier Aggregation and the QCI-1 bearer is established? In this case, it will impact the quality of the VoLTE Call.
