How change password oam Baseband 5216, 6630, 6631
Hey there, my friends!
I hope you’re doing well! Could you help me out with something? I’m trying to change the password in the radio node, for example, Baseband 5216 6630. Do you happen to know where I can find that MO, right ?
Thanks a bunch!
Hi, @rmncalix, which exactly password you want to change?
in this MO SystemFunctions=1,SecM=1,UserManagement=1,UserIdentity=1,MaintenanceUser=1
You can, but it is for ssh login:
Password used for SSH based login.
If no password is given, SSH based login will not be available for this user.
