Hello Experts,
I have a basic question: How does a gNB detect Radio Link Failure (RLF)? Is there a specific procedure or method for the gNB to identify this?
Thank you!
Hello Experts,
Thank you!
Will gNB allocate UL resource if UE link quality poor (out of range)? | 0 | 208 | December 19, 2023 | |
How gNB decides pointA? | 0 | 382 | July 29, 2022 | |
How eNB can detect how many users in there beam area? | 4 | 430 | October 5, 2021 | |
How communication takes place between AMF & GNB for QFI 1 establishment? | 0 | 307 | May 24, 2023 | |
How to find UL interference in LTE-NR scenario? | 0 | 572 | September 14, 2021 | |
How will gNB find the best AMF while multiple AMF used in Network? | 0 | 398 | October 3, 2023 | |
What are the reason of 5G RRC failure for 5G SA network | 0 | 631 | January 28, 2022 | |
How does gNB indicate session AMBR to UE? | 8 | 40 | September 25, 2024 | |
What AMF will check before sending the registration reject to UE? | 0 | 303 | December 15, 2022 | |
Does gNB trigger BSR reporting? | 0 | 300 | April 12, 2022 |
