How many maximum PDSCH beams are possible in one TTI (0.5 ms) for SRS based beamforming for FR1?
Which vendor?
Huawei has 16 pdsch layers for MU-Mimo in dl regardless if PMI or SRS.
Also 4 PDCCH layers for mumimo.
And in UL has 8 PUSCH layers for mumimo.
Only criteria is that UEs to be paired properly.
What about the SU MIMO?
Not vendor specific.
I mean any limitation in the no of PDSCH beam.
Also any relation with the SS block.
I think maximum 4 layers for sumimo.
Suppose there are 10 UEs and 8 UEs are using RI=1 and 2 are using RI=2 ( no mu mimo).
So how many total no of PDSCH beams will be required in that particular TTI?
Is it 10 beams?
