How many retransmissions including initial transmission we see in practice?
For example, when the UL PUSCH is to be retransmitted over N retransmissions.
What is normal range of number of PUCCH retransmissions before UE moves to RACH? | 0 | 240 | December 29, 2023 | |
How many HARQ timers are maintained in UL? | 2 | 412 | October 19, 2022 | |
Maximum preamble transmission Count and maximum rla reTx count in 5G | 0 | 431 | February 17, 2022 | |
Number of RRC connection setup failures due to PUCCH resource allocation failure | 0 | 718 | June 9, 2022 | |
Pusch restrictions | 0 | 568 | November 25, 2021 | |
How many RBs are allocated for PUCCH when you used short PUCCH and long PUCCH? | 0 | 418 | March 22, 2022 | |
Change of short PUCCH to long PUCCH increased PUSCH Throughput | 1 | 437 | March 22, 2022 | |
Can same information be transmitted in PUSCH than PUCCH? | 1 | 283 | September 13, 2023 | |
Ratio of RU to DU to CU in current deployments | 0 | 211 | May 30, 2024 | |
How do we encode UCI | 0 | 448 | February 16, 2022 |
