Hi All,
Can anyone explain me in simple words how path loss is calculated by UE?
My understanding it’s as per measured RSRP.
I’m seeing there is no standard equation.
Hi All,
RS Power of eNB - RSRP at UE = Path loss
Sib1 broadcast eNB TX power?
Sib2 Rs power.
You can check below link, it quite detailed:
I read somewhere that maximum Pathloss is 152 dBm. But why it is 152dBm?
Is there any mathematical calculation for max Path Loss?
Of course there is link budget calculation with many elements like antenna gain etc.
And also Rx sensitivity.
And check this, quite detailed indeed:
Pathloss is expressed as dB not dBm. As gain or loss is ratio of output and input powers.
Whereas signal strength is expressed in dBm as the reference power is taken as 1mw.
If the signal power level is 500me then in dBm it will be expressed as 10 log ( 50010^-3/110^-3) = 27 dBm
Path loss L= 20log(4*π/c) + 20log f + 20log D
If f is in MHz and D in km then path loss L = 32.4 + 20log f + 20log D
If f is in GHz and D is in km then path loss L = 92.4+20log f + 20log D
