QoS is Quality of Service.
It aims to forward traffic efficiently and perform bandwidth utilization.
QoS used to classify traffic and assign specific priorities and forward the traffic based on priorities.
It helps handling real time traffic, voice and video efficiently and even data traffic.
QoS works with L2 and L3 frames and packets.
WDM and optical devices L2 cards support Qos protocols.
QoS has 4 processes :
- Classification
- Mmarking / policing
- Queing
- Scheduling
Classification means assign forwarding class for each traffic flow depends on types of information carried by packet, we have 8 forwarding class based on importance and type of traffic.
Policing means control bandwidth used by each traffic flow, identify whether the income traffic is over , below or within the committed rate.
Policing called coloring, we have colors for the packets.
- Red : if the incoming packet bandwidth is greater than the peak Information rate ( in that case we have to discard )
- Yellow : if the rate of packet is between the peak and committed data rate , in that case we will discard the packet only if congestion occurred
- Green : if the bandwidth is lower than the committed rate , in that case the packet Forwarded normally
Queing means put the traffic in it’s specific Queue , FIFO is First in First out , move the packet from ingress to egress Ports.
It’s about how to order packets into the egress buffer memory.
Scheduling means select the SLA ( service Level agreement ) for each packet , we have different schedulers types as below.
- Strict priority
- Round robin
- Weighted round robin
- Weighted deficit round robin
LinkedIn:
