Hello NR Experts.
I have query regarding CA addition in SA network.
Let’s say UE add CA for n78_n41
n78 is pcell and n41 scell
UE latched to n78 with 2 SSB beams and n41 with single SSB.
Then during CA addition with n41 how SSB config done?
Will UE drop SSB for n78?
At a time, UE can be served with only one SSB beam.
Thanks!
At CA addition you mean all bands with single SSB only works?
Like CA-n78-n41
n78 pcell with single SSB + n41 with single SSB?
Even without CA it would be single SSB for CA.
If UE is 4 RX, then 2 SSB can be used at a time.
Why you mentioned single SSB always?
What do you mean by 2 SSB?
Are you referring to 2 PSDCH beam?
At a time only one SSB beam will be serving beam.
Please let me know if any misunderstanding…
Actually its seen with 2 SSB data flow there on 4 layers.
PDSCH layer are different thing and SSB serving beam is different.
I think it’s vendor specific like Huawei having different
For Nokia it’s same only.
But serving SSB beam would be only one at a time irrespective of vendor.
It depends on vendor.
Nokia old time was able to deliver only via SSB beams.
But now I think they have PDSCH beams as well.
Same Like Huawei.
Huawei also have PDSCH beams.
Question is not about PDSCH beam but pure SSB beam. Can UE be served by 2 different SSB beams at one time?
SSB beam, which UE monitor for mobility.
For mobility UE monitor multiple beams and which all beams need to monitor, n/w convey this info to UE.
I mean how many are serving beams?
Serving beam is 1 only as per my understanding.
Mine too: there can be only one.
Besides SSB beams have different locations in space.
So there will always be only one dominant, unless UE stops somewhere in-between them to have same RSRP from different SSB beams.
A UE can measure and report multiple SS PBCH Blocks simultaneously.
It depends on configuraiton of the parameter groupBasedBeamReporting as per 38.214.
I didn’t fully follow the conversation, but if this is what you are looking for…
Exactly this was only my point!
I think Ericsson has just one SSB for entire cell.
