How to analyze SCFT KPI for 5G?
Hello All.
Check if it is helpful for you:
Check this too:
SCFT || SCFT KPIs FAILURE’S SOLUTIONS || SINGLE CELL FUNCTIONING TEST
What is SCFT?
It is a test to check a cell functionalty after changes and / or activation. Some call it SCFT, others call it SSV.
Other test / names:
  • Single Site Verification (SSV) or Single Cell Function Test (SCFT)
  • Multiple Site Verification (MSV) or cluster drive test
  • Operator benchmarking drive test (Market level drive test)
Hello , I think SINR can also be used as DT parameter for LTE and similarly SS-SINR for 5G NSA.
Depending on operator configuration of the Network and Vendor support one can use CSI metrices to for 5G.
