Anyone aware how to check current serving beam ID in QXDM logs of NR SA?
Log packet used for CQI reporting in 5G SA | 3 | 873 | July 6, 2021 | |
Any guidance on how to evaluate SSB working as planned in New site integration? | 1 | 327 | August 2, 2021 | |
How to calculate NR DL Scheduling using QCOM logs? | 0 | 351 | June 22, 2022 | |
How can I check if one antenna has 64 rx-tx or 32 rx-tx NR NSA midband? | 1 | 363 | March 27, 2021 | |
5G SA Drive Test sample log | 0 | 777 | November 24, 2021 | |
How to tell from traces if the user is being served by 5G NSA or 4G in Core? | 3 | 245 | April 17, 2024 | |
Check if Operators is having SA deployment or NSA deployment | 2 | 316 | May 21, 2022 | |
How to see UE transmitting periodic SRS in UE logs in QCAT? | 0 | 141 | June 15, 2024 | |
Is it possible to read the NZP type CSI Report from QXDM? | 0 | 178 | April 2, 2024 | |
How could I abtain 5G NR logs | 0 | 447 | November 22, 2021 |
