How to check Ericsson cell traces with GPB extension?
Through accessing ENM you may apply for schell scrpting there is a stream command and decoding too but for better visibility you might get Log Tool or similar tools othetwise you will get less data, very less.
hello Alireza
Thanks. the log tool you mentioned is it also a ericsson tool? is there any limitation on how many UE’s can be traced in ENM?
