How to check interference in one part of PRB in LTE?
Hello Expert.
Please in LTE how can I check interference in one part of PRB?
Huawei
You have OSS traces, with signal level per PRB in Uplink.
Is it possible to check RTWP for sector?
You can check UL interference, average and max, per each PRB, directly in OSS - counters or live values with traces.
RTWP for UL RSSI can be checked in Nokia OSS KPIs too, counters divide while bandwidth into small chunks and each counter respresents a specific chunk.
So you can calculate where you have higher RTWP.
Yes for Nokia, I need any similar in Huawei.
I hope below video can help you:
Hi, do you have any method/counters to check RTWP/UL RSSI per PRB? Specifically Nokia?
