Hi ALl.
How to check maximum supported UEs in Ericsson node?
Any command is available?
Hi ALl.
get . Srusers
get . Cqiusers
These commands only display a capacity constraint at the cell level
The maximum UEs supported on Ericsson enodeB depend on the HW type and mixed mode configurations. In the LTE RAN libraries there is an xls: Supported Capacity and Configurations, with the details. Here I put some details for the most common HW, but it is necessary to review the original document, because there are some functionalities required to achieve the maximum configurations.
