How to check MOS value in QXDM?
To check the MOS value in QXDM, you can follow these steps:
The MOS value is a measure of the perceived quality of a voice call.
It is calculated on a scale of 1 to 5, with 5 being the best possible quality.
A MOS value of 4 or higher is considered to be good quality, while a MOS value of 3 or lower is considered to be poor quality.
