Hello dears.
Can I ask about how to convert NEMO logfiles to text file without using windcatcher?
Any idea Gents?
What is the extension of NEMO files?
It is .nmf
I think you can open nmf file in notepad++ & from there copy in text document.
It is openned dear.
But not showing the layers messages, most of the text is some signs and hashes.
If you have access to other tools like Actix, you can check all layer messages or events from there easily.
Yes brother.
The thing I was trying to convert without those tools.
But I guess I have to use it.
Thank you.
