Hello Ericsson Experts.
How to create term points on LTE nodes between 2 different operators with same vendor?
Any specific features/parameters we need to activate or define on nodes?
Hi, depends on how you want to share RAN.
There are several features you need to activate.
Then create AdditionalCoreNetwork and assign it to termpoint.
Thanks!
Do you have any list of parameters or features that need to activate?
For Ericsson:
Shared LTE RAN FeatureState=CXC4010960, optionally you maybe need Multiple IP addresses for S1 and X2
Is the IP reachable between these 2 nodes there?
Usually x2 between operators will not be reachable so suitable way to communicate via S1 interface.
If IP is reachable then you should be able to enable X2 termpoint.
IP is not reachable.
Then X2 termpoint will not be established so in your case only S1 communication is possible.
What to do to get IP reachable?
This you have to check with txn planning team whether they have ip access to other operator nw.
If it’s there then virtual routers need to be defined from baseband to establish the connectivity.
