Hi, @kayakaan, lteCellTraceFileDecoder avaiable in ENM:
$ lteCellTraceFileDecoder -h
usage: lteCellTraceFileDecoder [-h] [-nc] [-f {DEFAULT,JSON_FORMAT}]
[file_name]
LTE Celltrace Decoder - decodes LTE Celltrace files to a compressed csv format
Output directory will be /ericsson/tfd_cli_output/LTE_CELLTRACE
positional arguments:
file_name specify full path and name of the file to be decoded
optional arguments:
-h, --help show this help message and exit
-nc, --no_compression
disable compression for the current file
-f {DEFAULT,JSON_FORMAT}, --output_format {DEFAULT,JSON_FORMAT}
Output format of the decoded file
Full path to file must be specified
The disk usage volume is checked prior to decoding files and if the threshold is exceeded, no new files will be decoded until old files are deleted.
Decoder will skip already decoded files. File is considered decoded if a file with the same name and applicable extension exists in the output directory.
Hi @kayakaan. Yes, cell traces maybe decoded with ltng decoder. There is also logtool to decode them with GUI. But both tools are considered as Ericsson internal and I never seen them in public domain.
