Tg Ayomide Shobola (Nigeria):
Good day Engineers,
Can someone pls help with the suggestion on detection of External Interference while doing drive test on 900 and 1800 LTE band.
Customer experience is bad.
Tg Syabani (Malaysia):
Is it high UL RSSI?
RSSI doesn’t indicate either UL or DL
But the value is -80.81dbm
U mean interference toward BTS or UE?
After Optimization, I was able to achieve RSSI of -70.68
Interference toward UE
Since it’s external interference, I believe it affect the two
Only certain area or all over?
Certain area
Your value seem like ul rssi to me because thats the one we always look at
Try to get performance ul rssi stats
how
Can see whether it is always high or only at certain time
High ul rssi can be many sectors
Can the UL RSSI stat be detected while drive testing?
Some i can think of is increase of traffic, poor cable installation, and also external device
And No, UL RSSI can only be collected on BTS side, that means from moshell if its ericcson
To detect external interferEnce you need a scanner…
You might be able to proof there is exernal device inyerference, but to locate where the device, is very very difficult
That value from DT is DL RSSI?
-70 dbm is of course better than -80
Yes
Can BLER show interference?
Tg Zeggari Nabil (Nigeria):
I think you have to use scanner as pctel with tems investigation or use spectrum analyser to detect external interference, the best one use spectrum analyser
Tg Yaseen Al-Zuraiqi, (Yemen):
Do you have CDMA2000 carriers (operators)?
CDMA2000 may cause external interference on EGSM band
The LTE bands are 900 and 1800
I don’t think CDMA has its bands
CDMA2000 licenced in 800 bands may effect on 900 Mhz bands
OK
No CDMA network in Nigeria, Just 2G, 3G and LTE with 700MHz and co
Ok sorry
What about jammers…?
Does your customers live near a military area or governmental buildings or anything like that?
Tg Sanurianto Nuri (Indonesia):
Can you give me the details of network condition like number RSRP and RS SNR?
After optimization has been completed, RSRP value is -96dbm and SINR 3db
Tg Ali Raza (Pakistan):
Check SIB 7 messages
