How to disable complete data traffic on 3G Networks?
Hello 3G Experts,
Is it possible to completely disable data traffic?
If so, please suggest how. While it’s possible to disable HSDPA and HSUPA traffic, R99 traffic cannot be disabled on Nokia equipment.
How about deleting the RAC definition on the core side?
I think it can be done.
We have the option to disable PS services in Huawei while allowing CS services to run smoothly, though I’m not sure about Nokia.
Yes and No. Yes if you can block codes based on spreading factor (SF), block the r99 ps services codes.
Normally voice is placed on SF=256, 128 and 32.
Block the rest.
