Hi All,
How to enable handover from 2G to 3G?
Vendor Huawei.
We prefer HO from 3G to 2G and only reselection from 2G to 3G.
Yes, but here handover is happening from 2G to 3G and I want to disable it.
Interratoutbschoen=yes
Ho_inter_rat_cs_out_switch-1
Thank you, got the command. SET GCELLHOBASIC:IDTYPE=BYID,CELLID=0,INTERRATOUTBSCHOEN=YES;
It is not recommended to enable HO from 2G to 3G, because it is a completely blind HO and also degrades both 2G and 3G KPI, mainly call drop increases due to interference
Still for proper handover procedure, below parameter need to checked properly:
SET GCELLCCUTRANSYS: IDTYPE=BYID, CELLID=0, SI2QUATEROPTIMIZEDALLOWED=YES, FirstSI2QuaterMsgOptSw=ON;
SET OTHSOFTPARA: Send2QuterFlag=YES, SendUtranECSCFlag=YES, CLASSMARKQUERY=YES;
SET GCELLSOFT: IDTYPE=BYID, CELLID=0, QUERYCMAFTERINBSCHO=YES;
SET GCELLCCUTRANSYS: IDTYPE=BYID, CELLID=0, QI=7, QCI=Always, QP=7, QSEARCHC=7;
SET GCELLHOBASIC: IDTYPE=BYID, CELLID=0, INTERRATCELLRESELEN =YES;
SET GCELLHOUTRANFDD: IDTYPE=BYID, CELLID=0, BET3GHOEN=YES,
HOOPTSEL=Pre_3G_Cell;
Hope it will help you… please share your feedback after activation
