How to fetch specific Ericsson counter in CLI on ENM?
I’ve heard it is possible, but didn’t find in ENM library (Elex).
I know paramter dump of specific MO can be generated through cmedit.
cmedit did not work for counters.
Let me know if you find anything.
Counter or MO?
Counter.
Hi @alireza_moradi, are you looking for this?
For ERBS001 get all instances of the MOs of type ManagedElement and ENodeBFunction, specifying all persisted attributes on the ManagedElement and PM Counters on ENodeBFunction MO
Note:The search shall be contained to look for all MO instances under MeContext=ERBS001
Example Command:
cmedit get ERBS001 ManagedElement.<p>;ENodeBFunction.<pm>
