Does any one know how to get layer3 messages from Actix?
Go to hometab and then select protocol browser and select from there what you need.
First you have to select the log (left click on it).
Is it possible to export L3 messages as PCAP in drive test processing software? | 3 | 62 | July 31, 2024 | |
How to decode the Layer 2 and Layer 3 Message in LTE and 5G | 0 | 362 | November 7, 2023 | |
View Nemo log in Actix | 0 | 770 | April 10, 2021 | |
Alternative Tools for analyzing Layer 3 Message flows on Chinese-origin Phones | 1 | 11 | December 16, 2024 | |
In which SIB message can we see the LAC info? | 2 | 514 | May 22, 2022 | |
How to find "VoLTE Health Check" report in Actix? | 1 | 476 | January 11, 2023 | |
Checking TP or TA (Timing Advance) from Drive Test logfiles | 5 | 1248 | March 8, 2022 | |
Actix Analyzer - Some attributes are not showing on Map | 1 | 839 | April 2, 2024 | |
How to check IP address assigned to UE in layer 3 messages? | 1 | 331 | November 11, 2022 | |
How to check from Logs if SRB3 is implemented in network? | 6 | 540 | June 6, 2021 |
