Hi Team,
Can anyone suggest how to improve 3G download throughput? We have a single server with Rscp 85, speed getting less than 1 Mbps and sometimes we get a network error.
Any suggests on what should be done for further improvement?
There is no any congestion and no frame loss.
Stanis
September 16, 2017, 11:27am
5
Check the number of users
Number of user are less. Cqi is good.
Even we did change processing set as well… But still speed is same,no any improvement
Already discussed there is single server. Could u suggest the reason for poor cqi?
There are mutiple reason…major reason is interference, cell overshooting,
Stanis
September 16, 2017, 11:28am
9
Check the IP performance , jitter , delay and the flow control drops
Thanks will check,any other suggestion
Stanis
September 16, 2017, 11:29am
12
It might be there is a cap on downloading against your sim
Sorry dear. I didn’t understand
Stanis
September 16, 2017, 11:30am
14
Check the power and code utilization also
Which kind of system module?
Did you check throughput step parameter?
Fsmd system module is there
So it’s like 11subunt? From ce utilization sheet, can you check max used cesr? And Max n hsupa u util r from node b utilization sheet?
Also check number sus bb, Max bb, Rtwp?
