Hi How can I improve the Throughput in 3g??
Check fsmf card fbba card addition
Twin beam
For optimisation improve ecno.
Check mimo config and 64qam enables or not
Good Cqi value is must… to get good modulation scheme
Ok thanks…
check power blocking code blocking
check power congestion if any
check hspa processing set upgradation… if its high… check CE utilization if its high
Check transport fail… frame loss… iub felay
Check if there is BTS fails if any
Cac bandwidth also
Check cac bandwidth for transport level
This card belongs to which vendor??
The vendor is Nokia
Implement Dual Carrier
Yes, the setting might be different
For huawei do you have any idea?? Which card used
For Huawei, the card is Wbbpd
dear,
you can change the parameter If this parameter " Rate ratio thd of TTI 10ms To 2ms" in low value
